Ms. Pac Man / Galaga Model 9600
Question from Lori: The picture is slightly too big for the monitor so it cuts off the men and part of the score. I know how to get to the crosshatch screen but I have no idea how to adjust it from there. I would appreciate any help you can give me. Thank you so much. Lori
Jonathan Leung Jonathan Leung Staff March 14, 2016
Response from Jonathan: Lori,
Highly recommend checking out our post on Adjusting An Arcade Monitor. Although your monitor maybe slightly different from the one we use as our example, the concept should be same. Now, there is a chance that you may not be able to locate an adjustment to fix your width issue. In this case, you may need to resort to adjusting the horizontal width coil instead. Please see our post on Adjusting The Horizontal Width Coil for more information on this process. Hope that helps.
